Nominal door lining size?
Gavski1
by Gavski1 » Thu Feb 23, 2023 12:30 pm
Looking to do my first door (762 x 1918) and need to give builder dimensions for the studd wall gap. I'm a bit confused with door lining size -
Nominal Size: 32 x 115mm (Finished Size: 27.5mm x 108mm)
So which of these will I get off the shelf??
Will I get the nominal size and have to trim it down, or the finished size?
thanks
Re: Nominal door lining size?
by stoneyboy » Sat Feb 25, 2023 10:03 pm
Hi gavski1,
Presumably you are installing a standard 762x1981 door. Different manufacturers will use different thickness of lining timber so suggest you go to your preferred supplier and measure the finished and assembled frame size.
It is currently Thu Dec 26, 2024 11:15 pm
