hot water to taps and central heating system
veronica
by veronica » Fri Oct 12, 2007 12:24 pm
please can you help changed washer on hot tap in bathroom it worked but then no hot water in kitchen tap only a drizzle. now have no hot water or heating. drained the tank in the loft to see if it was to do with the valve on pipe to emersion heating had lot of water flow out of there. no problem with the heating or hot water on other taps till we mended the bath hot water tap . please can you suggest what else to try. mant thanks veronica
bobplum
by bobplum » Sat Oct 13, 2007 7:10 pm
i think people would need to know what system you have
It is currently Fri Nov 22, 2024 10:09 pm
