by geoff lee »
Sun Oct 14, 2007 2:20 pm
[quote="The Heating Doctor"]Was it only the boiler that was changed? If so was there any valves between the boiler and the cylinder closed off that may not have been fully reopened? Are the AAV's fully working? The AAV's have small orifaces which can be clogged by debris from the work carried out, could be worth making sure they are clear and working ok.[/quote]
no valves in between, aav's ok, boiler exchanged was an old wall mounted ideal boiler about 20 years old, flow and return from cylinder to boiler approx 3metres, return going into common return just before entering boiler, i suspect the coil externally could be scaled, as i have now been told the previous boiler took just as long.
