Valves Gummed up?
omits
Valves Gummed up?
by omits » Sun Apr 02, 2023 8:19 am
I have several water supply valves which don't turn off.
1 Two 50 gal tanks in loft with outlet 22mm valves (brass). When I turn them fully off (they go all the way) water still comes out of the bath tap (not mains). Is there a quick fix? I would need some sort of bung to stop the flow in both so i can undo them. Note both tank outlets feed to the same down feed so I can't just turn one off.
T-------X----|
|------------ to house
T-------X----|
2 There are two 15mm valves near my hot water tank. Both are stuck. Any ideas how to loosen them?
I have a very scaly water supply so I guess thats the problem.
Re: Valves Gummed up?
by stoneyboy » Mon Apr 03, 2023 9:58 pm
Hi omits,
Try removing the handles and then using mole grips direct on the shaft. Keep rotating the shaft backwards and forwards to free it.
It is currently Wed Feb 05, 2025 2:02 pm
