Help, Which wire is which
johnowhetton
by johnowhetton » Fri Oct 12, 2007 8:37 pm
i am currently replacing my socket fronts throughout my house, i have come to change the switch front for a storage heater, the trouble is the wires are not red and black, there is a brown wire and a green wire from the storage heater, i cant tell which wire is which does anyone have any ideas??
thanks
by sparx » Fri Oct 12, 2007 9:57 pm
Hi you should have from flex of heater a Brn. a Blue & a grn/yel earth to connect to your mains red, blk & grn / yel.
look carefully, as from your info you don't have enough cores to make a circuit. get a torch & find missing wires, regards SPARX
johnowhetton
by johnowhetton » Wed Oct 17, 2007 11:31 am
Hi Sparx,
Thank you for your reply, the wires coming from the storage heater are as follows,
i have a Brown Wire
i have a green wire
i have a green & yellow wire
would i be correct in thinking that the brown is live, the green is negative and the green & yellow is the earth??
thanks
john
It is currently Tue Jan 14, 2025 12:33 pm
