Are these "Metal wall Studs" as I cant to seem tfind any wood ones :(
OneADay
by OneADay » Sat Apr 08, 2023 2:21 am
Hi each and all I am looking for a little help, I have just replaced my central heating system and 2 x radiators will not be hung on a solid wall I was hoping to use battons attatched to the wood studs but I simply can't find them - I then went in the loft pulled back the insulation and it appears that this flat may have metal studs
https://drive.google.com/file/d/18W9JbG ... sp=sharing
https://drive.google.com/file/d/1NW_F2T ... sp=sharing
I am hoping someone in the know could confirm this by the pictures enclosed - many many thanks in advance
Darren.
Re: Are these "Metal wall Studs" as I cant to seem tfind any wood ones :(
by stoneyboy » Mon Apr 10, 2023 10:24 pm
Hi oneaday,
Looks like you have metal stud work for your ceilings, metal studs may have also been used for the walls - you will have to try using a stud detector to confirm and establish their location - if there are any.
It is currently Mon Dec 02, 2024 12:35 pm
