Karcher K4 not functioning...
EricLeBouffon
by EricLeBouffon » Sun Apr 16, 2023 6:22 pm
HI There,
This Karcher worked last time I used it (a year or two?)
Now, nothing happens when I press the trigger.
The power is on and the Karcher is buzing.
The water supply is fine.
Nothing lights up on the handle when I press the trigger (I "think" one of the symbols should light up...) and I do not get any water through.
I left the Karcher switched off with the water supply on for about 10mns.
First time I pressed the trigger, a tiny amount of water went hrough
Any idea?
Re: Karcher K4 not functioning...
by stoneyboy » Mon Apr 17, 2023 10:18 pm
Hi ericlebuffon,
Sound like the pump has seized, if you can get at the driveshaft or reach the impeller with a long screwdriver through the outlet hole, you may be able to free it.
EricLeBouffon
by EricLeBouffon » Wed Apr 19, 2023 9:44 pm
Thanks, I'll give that a shot next time I get access to it (in a few months from now I'm afraid)
Thanks for the idea
It is currently Fri Nov 22, 2024 12:06 am
