Cooker cable and fuse help please
paulhis7
by paulhis7 » Sun Apr 23, 2023 12:58 am
hello first post here
can some help please
just bought a new oven and grill not realising it will not run off a 3 pin socket
so my new oven is a 4,4kw
in my last house I ran a 10mm shower cable as my shower was 9kw and installed a 45amp fuse at the circuit board my question is can I run a 6mm cable and install a 40amp fuse at circuit board ?
I enclose photo of oven and fuse board
also any idea where I can buy HAGER fuse from
thank you paul
paulhis7
Re: Cooker cable and fuse help please
by paulhis7 » Sun Apr 23, 2023 9:15 pm
hope this phot is better !
paulhis7
by paulhis7 » Sun Apr 23, 2023 9:17 pm
40mcb or 45 mcb
by Mr White » Sun Apr 23, 2023 10:52 pm
You will need to test and verify that all is well, it is not just a case of switch on and if it doesn't go bang it must be ok
In this case you are going to need the services of an electrician.
It is currently Thu Jan 09, 2025 3:41 pm
