Pipes leaking on my boiler, how to fix
tom__l
by tom__l » Mon Apr 24, 2023 7:37 am
Hey, hope this finds you well,
My boiler is leaking from these two pipes:
https://www.dropbox.com/s/8o4ce6wyt9mop ... 2.png?dl=0
It's not tons of water, but enough to cause an issue - and the insulation around the pipes has become damaged as a result.
My question is - is this a situation where I need to get a plumber in, or is there something I can do myself to fix it? (i.e. could it be a simple case of tightening a valve, something like that).
All the best - any help much appreciated!
Re: Pipes leaking on my boiler, how to fix
by stoneyboy » Tue Apr 25, 2023 11:29 pm
Hi tom__1,
Unless you are Gassafe registered it is unwise to mess about under the boiler cover - suggest you get a Gassafe contractor in to solve the problem.
It is currently Thu Jan 02, 2025 10:57 pm
