Installing stone resin shower tray with riser kit
osirisluxor
by osirisluxor » Wed May 10, 2023 2:03 pm
looking for advice on installing a stone resin shower tray , using a riser kit
the riser kit uses sticky pads to install the adjustable riser legs to the underside of the shower tray , the underside is not totally smooth from where i assume it comes out a mold and i am concerned that the sticky pads may not get a good contact with the shower tray
i was thinking perhaps glueing a sheet of plywood to the underside first with the glue ( Gorrilla heavy duty adhesive) filling in the gaps and then installing the riser legs/pads to the plywood which would be smooth and more likely to get a good contact
has anybody done this or is there any reason i should not do this
TIA
Re: Installing stone resin shower tray with riser kit
by stoneyboy » Fri May 12, 2023 10:09 pm
Hi osirisluxor,
Suggest you buy some 2 part wood filler, use this the smooth the surface where the pads will fit. You will then avoid the possibility of rotten ply if water gets under the tray.
It is currently Mon Dec 02, 2024 1:37 pm
