Water ingress from overhead stairs
Jimmyk
by Jimmyk » Sun May 21, 2023 5:06 pm
Hi all,I have just joined,I was hoping for some advice,I have been renovating what in the past was an old outside toilet for my daughter outside of her flat.the said old toilet space has lain derelict for many years,the problem is there are stairs to upper flats above my daughters flat,I have rendered and plastered walls,however water is finding its way in from exposed steps above,I was going to rake out mortar joints and redo with some kind of epoxy waterproof repair,what do members think?thanks in advance,cheers
Re: Water ingress from overhead stairs
by stoneyboy » Mon May 22, 2023 9:45 pm
Hi jimmyk,
Assuming the steps are concrete, on a dry day apply a bead of silicone around the tread of every step. This should prevent standing water on the steps from seeping through. If this doesn’t stop the problem you will have to consider fitting a lead flashing down onto every tread.
It is currently Wed Dec 04, 2024 8:41 am
