Summerhouse build, door frame questions
Jocarl011
by Jocarl011 » Mon May 22, 2023 1:42 pm
Looking for some advice fitting a door to my summer house build. I was given an external door, large double glazed heavy thing. It has the stop trim all around the outside so I’m assuming I won’t need a stop fitting to any door frame I make?
The summer house is being made with 3x2 studs with 600 centres, 18mm OSB 3 on the outside and inside. Shiplap to finish. Will I need a frame for the door or can I just fix the door straight to the studwork?? Same for the windows too….. I’ve not built the front at all yet by the way.
Re: Summerhouse build, door frame questions
by stoneyboy » Tue May 23, 2023 10:34 pm
Hi jocarl011,
The door will need a frame and door stops, the windows can be fitted direct between studs.
It is currently Thu Jan 02, 2025 3:44 pm
