Strange loft construction and bracing?
Daddum61
by Daddum61 » Mon May 29, 2023 12:27 pm
my daughters house (built in the 50s i think) has some styrange bracing in the loft
the rafters sit on a purlin
then there are what look like purlin posts but they dont actually touch the purlin
initially i thought it was a retorfit to stop the rooff sagging or something but the timber looks similar age to the rest of the loft timbers
the diagonal braces as positioned so the meet over the wall between the bedrooms hence the different angles
and there is another purlin running over the bottom of these braces, you can see the pipes sitting on top of this
Re: Strange loft construction and bracing?
by stoneyboy » Tue May 30, 2023 10:16 pm
Hi daddum61,
The vertical (or near vertical) struts were probably fitted during construction to locate the purlin between them and the diagonal braces. Left because the builder couldn’t be bothered to remove them.
It is currently Sat Nov 23, 2024 9:45 am
