by ericmark »
Sat Jun 10, 2023 11:48 pm
With a modulating boiler the TRV can do most the control required and setting it up is the problem as wall thermostat needs to be slightly higher than the TRV so it only turns off on warm days.
But this has not really worked with non modulating boilers.
So mothers house it worked fine, this house not really worked.
The main advantage of the electronic head was it shows target and current, so if current exceeds target the lock shield needs closing a little until it does not over shoot.
The problem with the electronic TRV was over the top anti hysteresis software, so set at 7 am to 20 deg and it is 10 am before at 20, so had to set to 22 then down to 20 at 8 am, but this means the geofencing does not work.
So looking at more expensive models like Drayton Wiser, which works out how long it takes to heat the room.
But the eQ-3 which were only £15 each in 2019 when I fitted them, with bluetooth worked if anything better than the Energenie which was 3 times the price.
How the Terrier i30 work I don't know.
What are your aims?
