Void under resin tray former
MilliesDad
by MilliesDad » Wed Jun 14, 2023 12:12 pm
My recently installed solid resin shower tray / wet room former has around 4mm flex across a dinner plate sized area in the middle. It's on a concrete base that was unevenly screeded over. The gap will likely be under 10mm. It has not yet been tanked or tiled but would be a pain to entirely reinstall. Instead of taking the former out I'm thinking to drill a few small holes and inject a solution ( epoxy/polyester resin/ expanding foam) from the top of the tray to fill the voids underneath. Any thoughts appreciated.
Re: Void under resin tray former
by stoneyboy » Sat Jun 17, 2023 10:30 pm
Hi milliesdad,
Holes in the top will always be a weak point, could you drill the holes in the side and fit a small plastic pipe onto a foam gun to reach the inaccessible areas?
MilliesDad
by MilliesDad » Sun Jun 18, 2023 8:55 am
@stoneboy Solved - Prior to seeing your post I went ahead and sprayed minimally expanding foam through evenly spaced holes in the former surface while stood on it to mitigate distortion. It seems to have worked very well. The holes will be epoxied prior to the entire tray being tanked. Appreciate your input.
by stoneyboy » Sun Jun 18, 2023 9:59 pm
Hi milliesdad,
Thanks for the update, hopefully you stood on the tray long enough for the foam to set so there is no flexing.
It is currently Mon Dec 02, 2024 1:33 pm
