Should you undercoat when painting putty?
johnBmax
by johnBmax » Sun Jul 02, 2023 12:22 pm
When the putty is ready for painting, can you go on with undercoat first, without priming? or should you lip the glass with primer, undercoat, then finished coat?
Re: Should you undercoat when painting putty?
by stoneyboy » Mon Jul 03, 2023 9:45 pm
Hi johnbmax
Yes you should definitely undercoat the putty then apply finish coat.
johnBmax
by johnBmax » Tue Jul 04, 2023 9:47 am
Many thanks, so do I take it that the putty does not require primer?
by stoneyboy » Tue Jul 04, 2023 9:50 pm
Hi johnbmax,
No primer needed as long as you use oil based undercoat and finish coat.
johnBmax
by johnBmax » Wed Jul 05, 2023 1:52 pm
many thanks
It is currently Fri Nov 22, 2024 5:33 am
