Cistern feed for washing machine... parts needed and help
robod
by robod » Sun Jul 09, 2023 2:51 pm
Hi there,
Please excuse my lack of knowledge on this, my plumbing knowledge is very limited.
I have a cold water feed going into cistern with plastic pipe and push fits. It's a new built in cistern. I am looking to tap into the feed and add a water supply for a washing machine.
Can I just cut into the pipe (after turning off water) and add a three way push fit to add the washing machine connector to it? Or is there an easier/better way.
If it helps, it's a new build and Imputting a washing machine in the cloakroom and removing toilet.
Thank you for your help.
Rob
Re: Cistern feed for washing machine... parts needed and help
by stoneyboy » Mon Jul 10, 2023 9:58 pm
Hi robod,
Your proposal to fit a T will work fine. Use a sharp knife to cut the pipe (not a saw) and don’t forget to use inserts.
robod
by robod » Sat Jul 15, 2023 6:29 pm
Thank you - much appreciated.
It is currently Tue Dec 03, 2024 12:09 pm
