Hot Water Spilling Into Central Heating F&E Tank
PuzzledByPlumbing
by PuzzledByPlumbing » Wed Jul 12, 2023 5:16 pm
I have just had a bathroom professionally renovated. As part of this work a new boiler, CH pump and F&E tank ball valve were also installed. My boiler and central heating is an open vent system and was powerflushed as part of the boiler replacement.
A couple of weeks after the installation I noticed that hot water was surging via the CH expansion pipe into the F&E tank, yet the CH is switched off. I will be contacting the plumber who installed the boiler to look at the problem but would also very much appreciate the advice of this forum.
Re: Hot Water Spilling Into Central Heating F&E Tank
by stoneyboy » Thu Jul 13, 2023 10:47 pm
Hi puzzledbyplumbing,
You must get the installer back to correct the problem, it could be as simple as the pump is set too high or it may be poor placing of connections for the new components.
PuzzledByPlumbing
by PuzzledByPlumbing » Fri Jul 14, 2023 11:26 am
An observational update. The E&E expansion pipe is hot even without any domestic water being drawn off, i.e. when water is heating up in the morning.
PuzzledByPlumbing
by PuzzledByPlumbing » Fri Jul 14, 2023 11:28 am
And there is no automatic bypass valve fitted. (sorry for the drip feed - no pun intended)
It is currently Thu Nov 28, 2024 2:01 pm
