Raising a drainage chamber to new ground level
Doitall
by Doitall » Tue Jul 18, 2023 3:32 pm
I have been building a small new utility room over an existing 235mm internal diameter (250mm external diameter) drainage chamber and need to extend the shaft upwards by about 220mm to the new ground level. I have recovered the existing lid and frame for fitting at the new height.
However, I cannot find any drainage product that will fit over the existing shaft.
I'd be grateful if anyone has any ideas?
Re: Raising a drainage chamber to new ground level
by stoneyboy » Wed Jul 19, 2023 10:10 pm
Hi doitall,
You may have to buy a 250mm inspection chamber and cut off the depth of rings you need, then glue it on the existing chamber.
Doitall
by Doitall » Wed Jul 26, 2023 4:14 pm
Thank you Stoneyboy.
I considered doing that but then found the 'Marley Underground Chamber Riser' for £32.90. I cut it to the right length, then stuck it on by wrapping with Evostick tape and concreting around. I'm hoping it works. Thanks for your advice though.
It is currently Sat Sep 28, 2024 8:32 pm
