One Gas fire for two rooms
mrmistoffelees
by mrmistoffelees » Sun Oct 14, 2007 9:03 am
Hi all, first post so please be gentle !!
Just moved into my new house and it has a gas fire in the living room and mirrored in the dining room there was a fireplace which was in the exact mirror image of the one located in the living room.
What I would do is knock through the two fireplaces and have one open fire (something like a fire basket) serving the two rooms)
Where do i start and what do i need to be wary of ?
Many thanks in advance
by htg engineer » Thu Nov 01, 2007 5:46 pm
You should be posting this in a builders/brickwork forum as it's the support you are removing for the chimney stack and the rest of the house that may be a problem. And the arrangement to disperse the loads that should be the main concern.
You can fit basket style fires in this way shouldn't be a problem, but as i say it's the building work that needs to be planned and thought through first. With specialist structural advice.
You will probably have to get a professional out to have a look, as there's many house styles. They will not be able to offer advice without seeing the house.
It is currently Sat Dec 28, 2024 11:48 am
