Anchor wall mount stool to to plasterboard
NBUK1994
by NBUK1994 » Fri Jul 28, 2023 6:50 pm
Hello,
I am trying to install a foldable stool that mounted to the wall in the hallway. There is no stub behind the plasterboard with thermolite block works behind the plasterboard.
How do I wall mount the stool securely to bear around 70Kg loading/body weight
Re: Anchor wall mount stool to to plasterboard
by stoneyboy » Sat Jul 29, 2023 9:46 pm
Hi nbuk1994,
Assuming the stool brackets have multiple screws holes - Drill through the plasterboard and into the thermalites, assuming the thermalites are 100mm drill around 75mm depth into the blocks. Fit plastic wall plugs into the blocks then use expanding foam to fill the gap between the back of the plasterboard and the blocks - allow it to harden, probably 24 hours. Then fix to the wall you’ll probably need 100mm screws.
NBUK1994
by NBUK1994 » Wed Aug 02, 2023 10:21 pm
Thank you very much for your advice.
It is currently Thu Jan 02, 2025 12:42 pm
