Wooden flooring - which underlay?
pickup01
by pickup01 » Wed Mar 28, 2007 2:42 pm
I'm about to put down a solid wood tongue&groove floor over existing quarry tiles and wonder what type of underlay I should use. The room is on the ground floor of the house. Can you advise?
thedoctor
by thedoctor » Wed Mar 28, 2007 3:27 pm
Double up on a laminate underlay
T E Partington
by T E Partington » Tue Apr 17, 2007 2:21 pm
you should buy laminate underlay with a built in damp proof membrane, its silver foil on the reverse side, when you lay the underlay turn it up the wall a few inches and cover it with your skirting board, any moisture will expand the timber and bubble the floor, you should also consider storing the timber in your house for a few weeks to aclimatise
jezebelle
by jezebelle » Tue Apr 24, 2007 8:13 am
What is laminate underlay?
Would'mt this underlay raise the floor quite a bit?
It is currently Sat Nov 23, 2024 2:31 am
