Replacing plywood bathroom floor
Bentura
by Bentura » Mon Aug 28, 2023 12:06 am
I'm replacing my bathroom floor. It did have tiles, but I am replacing with vinyl. There is 12mm plywood under the tiles, but because I'm removing tiles which were about 1cm thick (with adhesive) I will end up with a difference in height which will affect the toilet height and gap under the bath side. The 12mm board goes under the door frame. So I can't just replace it all with 18mm for example to make up the height difference.
I plan to replace the 12mm with new 12mm ply, and then use 9mm ply on top. With vinyl being around 3mm, I think I'll be OK with the toilet and bath side.
Does that sound OK to do? Also, do I need exterior ply as the vinyl should provide the water resistance.
It is currently Thu Jan 02, 2025 3:00 pm
