Checking damp level in wall prior to repair
optimusrhyme
by optimusrhyme » Wed Sep 20, 2023 10:48 am
After noticing some dampness, discolouration and deterioration on the wall around the chimney breast I had a handyman take a look. He found a few problem areas with the chimney stack that he repaired and then finished by coating the entire thing with water seal.
Assuming all is now good externally, how might I go about determining the damp level in the wall before doing any internal repairs? I have a dehumidifier running in the the room at present and hope to be able to box out the wall around the chimney breast once it's dry enough to do so as there doesn't appear to be any insulation between the chimney breast and my internal wall.
Any advice you can provide would be greatly appreciated. Thanks in advance.
Re: Checking damp level in wall prior to repair
by stoneyboy » Thu Sep 21, 2023 10:04 pm
Hi optimusrhyme,
Buy a damp meter and take readings over the next couple of months to check progress. If you have just had the remedial done it will be some time - months rather than weeks - before the damp dries out.
optimusrhyme
by optimusrhyme » Fri Sep 22, 2023 9:45 am
Thanks Stoneyboy, I appreciate the advice.
It is currently Sun Dec 22, 2024 10:28 am
