Clay channel repair
RuLidd
Clay channel repair
by RuLidd » Sat Sep 23, 2023 4:00 pm
Hello,
I am new to the forum so hope this is posted in the right place.
I'm looking for some advice on a repair of a section of clay channel that is set in a old concrete inspection chamber. The channel section has cracked into a number of loose pieces on a bed of water saturated soil.
I believe the rest of the drain is sound and the waste flows well. However water is seeping into the ground with every flow.
I think I can source a replacement section of channel but I'm not sure how it should fitted. Should it sit on a particular bed? Should that be mortar, concrete or some sort of compacted aggregate?
Assuming mortar will needed to fix and point the channel, does it need to be a particular mix?
Any other any advice for carrying out the work would be helpful.
R
Re: Clay channel repair
by stoneyboy » Sun Sep 24, 2023 9:43 pm
Hi rulidd,
Dig out the bottom of the chamber, cast a concrete base, lay your new section of pipe on/in it and render around it with a sharp sand + cement mix.
RuLidd
by RuLidd » Mon Sep 25, 2023 8:29 am
Hi stoneyboy
Thanks for the advice, that's very helpful.
R
It is currently Mon Dec 02, 2024 2:59 pm
