Plasterboard not attached to wall or fixings failed,
saljia
by saljia » Thu Oct 19, 2023 10:21 pm
I'v just started to strip a bedroom wall and one wall wobbles. My house is approx 120 years old and built of solid stone, the walls were lined with plasterboard by a previous owner. There is a small possibility that insulation was put in but, I don't know. The plasterboard has been skimmed and looks fine. My first thought was to go along the wall and countersink some hammer fix screws as I've no idea where the batons are, if any. Would this work or, is there something better I can use? Advice please :)
Re: Plasterboard not attached to wall or fixings failed,
by stoneyboy » Fri Oct 20, 2023 10:15 pm
Hi saljia,
Possibly best to determine what is behind the plasterboard. Use a small sabre saw to cut a hole in the board - taper the edges so you can stick the cutout back in place. You can then decide whether to fix into battens - if they exist - or whether you need longer screws to fix into the masonry wall.
saljia
by saljia » Fri Oct 20, 2023 11:54 pm
stoneyboy wrote:Hi saljia,
Thanks Stoneyboy, I had thought of just making a hole but wouldn't have thought to taper it. I think it will be old bricks and stones if it's anything like the chimney I had removed a few years ago. Off to Amazon for a sabre saw, thanks again.
It is currently Fri Nov 22, 2024 11:59 am
