Advice in removing internal plaster beads
Samwp
by Samwp » Sun Nov 05, 2023 6:26 pm
We have a number of window reveals that might need to have the existing metal corner beads removed. I am looking for any advice on a way to remove the beads without causing too much damage to the rest of the wall. Any first-hand advice would be appreciated?
We known that the existing the beads are plastered on, not nailed.
Re: Advice in removing internal plaster beads
by stoneyboy » Mon Nov 06, 2023 9:43 pm
Hi samwp,
If you have dry lined walls use a sharpened scraper to get under the wings and lift them off the plasterboard.
If you have masonry plastered walls use a sharp bolster chisel, cut in behind the bead corner and remove plaster back so there is none of the perforated wing left, do the same for the other side.
It is currently Sat Nov 23, 2024 11:45 am
