Air admittance valve for slow flushing toilet
Bill50
by Bill50 » Mon Nov 27, 2023 2:36 pm
When flushing the toilet it is slow to drain and air bubbles up through the shower drain. If I remove the air admittance valve all works correctly.
The current aav seems to be opening and closing but does not operate when fitted. I have tried a replacement aav and the fault remains, however the valve was bought online and the box was damaged. Is it likely that both aav’s are faulty?
Thanks in advance.
Re: Air admittance valve for slow flushing toilet
by stoneyboy » Tue Nov 28, 2023 10:12 pm
Hi bill50,
Presumably you do not plug the hole where the AAV is fitted for the second of your tests. I also assume you have an open stench pipe at the highest point of your soil system. Most likely that there is a defect in the falls on the main soil pipe or you have a partial blockage. The problem will be finding it.
Bill50
by Bill50 » Wed Nov 29, 2023 10:42 am
Thanks very much for your response. I was thinking the same thing as the fault is intermittent and also Southern Water are regularly “fixing” drainage problems in the area.
by stoneyboy » Thu Nov 30, 2023 9:53 pm
Hi bill50,
Unfortunately water boards generally seem to have a sticky plaster approach to problems, hope you get your sorted.
It is currently Mon Dec 02, 2024 1:40 pm
