Radiator flow direction?
3magnet
by 3magnet » Mon Oct 15, 2007 2:05 pm
We have removed our radiators about 5 months ago when we first moved into our house to get them sandblasted and repainted. We wish to replace one regular valve on each radiator with a thermostatic valve, but we can't remember which way is the inflow/outflow side of the radiator...How do we figure this out?
bobplum
by bobplum » Tue Oct 16, 2007 9:45 pm
what kind of system do you have
bobplum
by bobplum » Tue Oct 16, 2007 9:55 pm
have you tried turning the heating on seeing what pipes get hot this will be the flow?
3magnet
by 3magnet » Thu Oct 18, 2007 5:40 pm
Hi Bob,
Thanks for the tip about turning the heat ona and feeling which pipe gets hot. We have the standard iron radiators, not the double convection (or something) type. If I fit thermal valves to them, would I still require the room thermostat and how will this influence the thermal valve?
It is currently Fri Nov 22, 2024 11:24 am
