Front step breaching Damp Proof Course
Laine
by Laine » Thu Dec 07, 2023 12:57 pm
Building survey on house purchase (1930's semi) says "front step appears to have breached damp proof course and be blocking subfloor ventilation". Some of the internal joists near the front door have therefore rotted. We are trying to work out how to rectify this with the least disruption, could we just put a channel/gap between the paving slabs and the front of the house in the area that is protected by the porch? If so approximately how wide would this have to be ? If this wouldn't work has anyone got any other suggestions that might help?
WhatsApp Image 2023-12-04 at 14.47.47-Edit.jpg (36.57 KiB) Viewed 662 times
Re: Front step breaching Damp Proof Course
by stoneyboy » Sat Dec 09, 2023 10:34 pm
Hi Laine,
You will have to form a channel along the length where the porch meets the house, the bottom of the channel needs to be 150mm below DPC level. If you remove the slabs and form the channel you should be able to replace the slabs. Either end of the channel needs to be taken through the porch walls so it is a ventilated space.
Laine
by Laine » Sun Dec 10, 2023 3:59 pm
Hi Stoneyboy Thank you for the reply it is really helpful.
Kind regards
Laine
It is currently Thu Jan 02, 2025 11:25 pm
