Bidet house on toilet - solid pipe
Jp_fondu
by Jp_fondu » Fri Jan 12, 2024 12:58 pm
Looking to install a bidet hose on the back of the toilet but all the videos I watch show a hose at the back of the toilet but I have a solid pipe. Also the pipe has a connection in the middle.
Would I just need to replace the lower solid pipe section with a hose, then I can attach the bidet connector as normal? Im thinking if I just throw on the hose connector the pipe will be too long.
Re: Bidet house on toilet - solid pipe
by stoneyboy » Sat Jan 13, 2024 11:12 pm
Hi jp_fondu,
Replace the solid pipe with a flexible tap connector of the appropriate length- curves in this will not be a problem.
It is currently Mon Dec 02, 2024 11:49 am
