Advice required on floor tiles
geek84
by geek84 » Mon Mar 18, 2024 9:56 am
Hi Folks
I am planning to fit some floor tiles in front of my front door at my property.
Can you kindly advise if I should buy several small tiles or some large tiles (which will obviously cover more area)
Are there any pros and cons of the size and is there any specific material I should buy?
Re: ADVICE REQUIRED ON FLOOR
by stoneyboy » Tue Mar 19, 2024 10:56 pm
Hi geek84,
Small tiles will make the area appear bigger and if the area outside your front door is enclosed, they will be easier to lay. If you are tiling an external area go for pavers which will have an unglazed finish so will be safer in the wet than a glazed floor tile.
Regards, S
It is currently Sun Nov 24, 2024 4:12 pm
