Can I strap 40mm waste direct to wall?
6 posts   •   Page 1 of 1
mattdownsouth
by mattdownsouth » Thu Apr 11, 2024 5:29 pm
Title says it all really - in the interests of saving a few mm on a very tight bathroom, is there any reason I can't strap 40mm waste pipe (say abs or pvc) direct to a plastered wall with nothing between? I would strap it down with a rubber or plastic strap band screwed into the wall.
I know clips are available but with the standoff they add another 10mm+ which means I'm at 53mm from the wall, so have to move up to 75mm studwork from 50mm :( It's also going to be tight behind appliances in the kitchen so I'm keen to know if there is a reason I can't strap direct to the wall surface.
Thanks in advance.
Re: Can I strap 40mm waste direct to wall?
by stoneyboy » Fri Apr 12, 2024 10:50 pm
Hi mattdownsouth,
Fix tight to the wall using large zip clips - screw the clip onto the wall and zip!
mattdownsouth
by mattdownsouth » Sat Apr 13, 2024 2:43 am
thanks stoneyboy. i cant find anything called zip clips online - do you have a link?
mattdownsouth
by mattdownsouth » Sat Apr 13, 2024 9:06 am
Thanks stoneyboy. I can't find a zip clip online - could you send me a link?
by stoneyboy » Sat Apr 13, 2024 10:46 pm
Hi mattdownsouth,
Sorry I should have called them zip cable ties - if you can find them use ones that are about 7mm wide.
mattdownsouth
by mattdownsouth » Thu Apr 25, 2024 1:53 pm
Anyone?
It is currently Tue Dec 24, 2024 2:17 am
