Strange loud noise when toilet flushes
ingridguerci94
by ingridguerci94 » Fri Apr 19, 2024 2:32 am
Just after the button is pushed to flush the toilet a strange noise can be heard. The toilet cistern is boxed into a cabinet set up. I can access the cistern quite easily and have had a look inside. The noise sounds like something getting stuck or parts rubbing together but I cant see anything obvious that would be causing this, the toilet flushes as normal.
There is a normal looking plastic ball valve in the cistern and another largeish plastic part that has a plastic tube comming out the top which is connected to the button to flush the toilet ???
Any suggestions as to what is wrong and how I fix it would be much appreciated.
Thank you!
Re: Strange loud noise when toilet flushes
by stoneyboy » Sat Apr 20, 2024 9:51 pm
Hi ingridguerci94,
The most likely culprit is the fill valve, to confirm try depressing the ball valve arm slightly.
It is currently Mon Dec 02, 2024 12:51 pm
