Worcester heatslave 18/25 combi boiler too hot
dandies
by dandies » Fri May 03, 2024 6:47 pm
Hi, Worcester heatslave 18/25 combi oil boiler is heating the water too hot, same problem last year ,engineer changed thermostat in the boiler at that time, why would it happen again so soon,boiler is 16 years old, thanks
Re: Worcester heatslave 18/25 combi boiler too hot
by stoneyboy » Tue May 07, 2024 10:57 pm
Hi dandies,
Failure of the thermostat is the most likely problem. If you didn’t last time can only suggest that you use an approved Worcester Bosch engineer to identify the problem and fix it this time round.
