Filling large gap around window frame
TonyB13
by TonyB13 » Thu May 30, 2024 9:35 pm
Hello, what's the best way to fill a big gap around the top of a window frame - about 1cm wide by 2cm deep by 40cm long? Different places have different suggestions: decorators caulk, stuff newspaper in then fill over that, use backer rod. Any guidance much appreciated. Thanks.
Re: Filling large gap around window frame
by stoneyboy » Mon Jun 03, 2024 11:14 pm
Hi tonyb13,
Suggest you use expanding foam, once it’s set trim it back and plaster over it.
It is currently Mon Dec 02, 2024 12:47 pm
