hole in wall!
laloo
hole in wall!
by laloo » Wed Oct 17, 2007 9:52 am
I have just removed an old gas heater from my house. When i removed it i found that there was a hole in the wall going directly to the exterior of the house to a metal vent. Does anyone know how I can fill this in? I have no idea.
thedoctor
by thedoctor » Wed Oct 17, 2007 5:21 pm
Remove any metal vents carefully, see our projects on mixing mortar, replacing a damaged brick and pointing brickwork. This will teach you how to lay bricks or brick pieces in the hole. The hole can then be plastered over. See our project on plastering. If the external hole needs to be "Fair Faced" brickwork, ie what you do is to be seen regularly, then use a hammer and bolster chisel to Cut out any brick pieces through which the hole was drilled so you end up with a square shaped hole rather than a round one. Try and keep the remaining bricks "whole" so the bond of the bricks stays intact (one brick overlaps the one below it by half of its length). Then fill the hole with new brickwork.
laloo
by laloo » Thu Oct 18, 2007 9:48 am
Thanks, that's a great help, i'll get to work!
TheDoctor5
by TheDoctor5 » Thu Jan 22, 2009 10:23 am
It is currently Fri Dec 13, 2024 12:33 am
