plastering around a door need urgent assistance
plasterpaul
by plasterpaul » Wed Oct 17, 2007 4:04 pm
Just wondered what the best method would be to render and skim around a door. Its the front door and requirs the sides and top plastering around the door. There is already plaster on the walls up until the door. I was going to use tiny batons but also i cant fit my trowel into the gap between the door and the walls. Help please?!
golfbidder1972
by golfbidder1972 » Fri Oct 26, 2007 10:39 pm
You can buy margin trowels at B and q or ebay which are thin trowels for this type of problem.if you want a good finish angle bead the edge of the wall and skim both sides of angle bead,or just try to feather the multi finsh into the existing wall...
It is currently Sat Nov 23, 2024 10:36 pm
