Storage heater problem
gkelly
by gkelly » Thu Oct 18, 2007 1:57 pm
This is probably a very simple thing but.....i know nothing about storage heaters!
My sister has just moved into a house that only has storage heaters. The one in the lounge doesnt work at all. How do we 'troubleshoot' - we have tried turning all the dials but still no heat - the others in the house are fine.
Not really sure where to start with this? And dont want to call someone out before we have an rough idea of what could be wrong....any ideas please?? Thanks (Its getting cold!!)
BLAKEY1963
Re: Storage heater problem
by BLAKEY1963 » Fri Oct 19, 2007 1:06 am
[quote="gkelly"]This is probably a very simple thing but.....i know nothing about storage heaters!
Not really sure where to start with this? And dont want to call someone out before we have an rough idea of what could be wrong....any ideas please?? Thanks (Its getting cold!!)[/quote]
Gkelly
Normaly over 13 amp so no fuse at double pole switch.
Only works at off peak 11 pm - 7pm so check storage heater mains board for blown fose tripped mcb ? reset / replace and wait for heater to recharge with heat.
if above does not fire up unit then get expert help in.
BLAKEY1963
by sparx » Sun Oct 21, 2007 10:26 pm
hi,GK,
as Blakey says they are each on own circuit which only comes live at night, one thing to check after fuse/mcb is inside top cover of heater is a thermal over temp. trip, which goes out if for instance heater is covered up & gets too hot.
Some are a fusible link which once failed must be replaced but some have a resetable type with a reset button, worth a look first,
regards SPARX
It is currently Wed Nov 27, 2024 12:49 am
