self leveling compound
7 posts   •   Page 1 of 1
AndyB
by AndyB » Sat Oct 20, 2007 11:39 pm
Hi, I'm going to be using some self levelling compound soon, before I lay some porcelain floor tiles, but have found two sorts. One has latex added and the other doesn't. What does the latex do and is it necessary, as its alot more expensive
kbrownie
by kbrownie » Tue Oct 23, 2007 6:37 pm
Hi AndyB,
Depending on what surface you intend to level it may make a difference, Latex will both strengthen the mix and provides a limited degree of movement capability in the sub floor. Ideal for use when covering sound timber floors. If it's concrete use the other stuff.
Hope helpfull
KB
AndyB
To kbrownie about self levelling
by AndyB » Tue Oct 23, 2007 8:30 pm
Hi, thanks for reply. the self levelling is to level the concrete floor from a new extension to the original floor of the house. The new concrete floor isn't that far out but it is quite rough in places. A problem I might encounter is that the original floor was covered in tiles which were stuck down with a bitumen paint.This paint is still on the surface of the floor, so would the self leveller stick to this. Another point is that the latex self leveller is around £20 a bag whereas the plain leveller is around £7 for same size bag. Quite a big difference in price really
SteUK
by SteUK » Fri Jan 18, 2008 1:29 am
Hope this thread is not totally dead as I have the very same problem! Though there is already water based self leveling compound filling in the gaps created by tiles lifting when removing the vinyl sheet flooring that was laid over the tiles.
What did you use in the end?
Ste
Terence
by Terence » Mon Nov 17, 2008 6:23 am
Hi my daughter has asked me to lay a new tile floor over an existing quarry tile floor. It seems a sound floor. We are unable to remove the old tiles as the Kitchen units are standig on them. Is self leveler a good start after Pva do i need to add PVA to the self leveler. I have not laid a floor for 20yrs but it is still good.
Terry
chris_on_tour2002
by chris_on_tour2002 » Tue Nov 25, 2008 12:03 am
why on earth would you want to lay tiles over quarry stones?!? cuh, some people ;-)
if the tiles are sound and level then you could tile straight on top, no need for an intermediate.
if not, then levelling compound. and i'd be inclined to use a latex primer rather than pva. you can buy admix for the self leveller, which i believe will make it into a latex self leveller anyway.
best advice is to follow the instructions on the packet for the levelling compound, all the information you need should be there. always best to follow manufacturer's guidelines.
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:46 am
It is currently Fri Nov 22, 2024 5:51 am
