power shower
Cu
power shower
by Cu » Mon Oct 22, 2007 1:25 pm
I'm installing a power shower to replace an existing mixer type. The plumbing should be ok, but the electrics are a concern. I will be getting an electrician in to do the work, but i want to understand what is involved.
It's a thermostatic power shower and as far as i'm aware the electrical connection is only to run the pump (not to heat).
All the web sites give guides for installing electric (heating) showers. Are the requirements for my shower as stringent? Do i need to connect direct from the fuse box (modern house type). Or can i spur off from an existing ring (in the loft) add a pull cord (3A double pole?) switch an lead the cable down the wall alongside the cold water pipe?
kbrownie
by kbrownie » Mon Oct 22, 2007 5:54 pm
Hi CU,
sorry can't be too helpfull, but you need Part P qualified sparky in.
Bathrooms now covered by Part P of building regs and all new circiuts and installations most be complient of them. Your Part P sparky will inform you if you ask of how the ciciut should be installed?
Kind Regards
KB
by sparx » Mon Oct 22, 2007 8:36 pm
Hi, basically yes except there should be a seperate chase for the cable not to touch the pipe,
regards SPARX
It is currently Tue Jan 14, 2025 10:47 pm
