Odd Interior door size
maggyhunt
by maggyhunt » Thu Mar 29, 2007 8:39 pm
Hi, where can I find timber interior doors with the following dimensions?
2036x720mm.
I've tried all the major DIY stores and none appear to supply that size. All I want is a standard 4/6 panel timber interior door and would like to get some without the huge cost of having to get them made. Please help.
thedoctor
by thedoctor » Sat Mar 31, 2007 8:53 am
Ask in builders merchants Maggy you will not get these sizes from Diy stores. Merchants like Jewsons and Travis Perkins should be able to order these sizes. They are however very large and it may be that even after ordering a larger size you need to reduce the size of the frame. This is not a huge job but try with the doors first and then come back if you need to reduce the frame.
It is currently Mon Jan 06, 2025 8:35 pm
