filling holes in a cratered concrete floor
Opey
by Opey » Mon Oct 22, 2007 6:56 pm
I want to take up an existing parquet floor which will no doubt crater the existing concrete surface underneath. I want to fill these craters without raising the overall level of the concrete. What product do I use?
kbrownie
by kbrownie » Sat Oct 27, 2007 5:54 am
Hi Opey,
When you say "crater" i'm guessing that you have a floor that is not absolute level. If that is so, you can buy a good self leveling compond from wickes. If you just need to repair holes in the floor a bit of limestone gravel no bigger 10/0mm and some grit sand mixed together with cement and water. Should be okay!
Best of Luck
KB
It is currently Fri Jan 03, 2025 5:30 am
