Wooden Window Sill in Bathroom!
7 posts   •   Page 1 of 1
barneh
by barneh » Tue Oct 23, 2007 7:03 pm
Can anyone help me please? We had someone do some tiling for us and for whatever reason they didn't tile the window ledge telling us that it 'would look better' with a piece of oak to form the window ledge. We think that he didn't want the bother of cutting the tiles as they are very thick, but that doesn't help us. Now we don't know what to do. Can you have an oak window ledge? Will it not swell in a bathroom? And won't it look stupid! We are stuck and don't know how to finish off our bathroom. Any help gratefully received.
Thank you
Oddbod
by Oddbod » Thu Oct 25, 2007 4:14 pm
Hi. What did you pay him for? You might feel it appropriate to tell him to come back and finish the job. Saying it “would look betterâ€
stevie boy
by stevie boy » Fri Oct 26, 2007 9:46 pm
if you have a nice new white suit why not fit a piece of upvc fascia board to the window seal it looks very clean and is easy to wipe down and needs no maintainence just cut to size and glue down (assuming you have upvc windows that is) hope this helps
dents
by dents » Fri Nov 02, 2007 12:56 am
i would guees he didnt want to do it for your reasons given or was not agreed upon .
did you remove your cill? so he could tile?
tilers do not like to do that sort of thing they want everything prepared for them as they are not that skilled.
cafetorium
by cafetorium » Fri Nov 23, 2007 3:22 pm
I have wooden window sills throughout my house, including the bathroom.
They are painted with white gloss paint.
My previous house also had wooden sills which were stained and varnished. They looked just fine and I never had any problem with them.
I would recommend Yacht Varnish, and a minimum of three thin coats, rubbed down between applications.
(By the way, can anyone tell me why B&Q Yacht Varnish says "not for marine use" on the tin? If you can't use Yacht Varnish on a yacht, what can you use?)
susanxx
wooden window sills
by susanxx » Sat Nov 24, 2007 11:06 pm
I had wooden window sills in my bathroom and kitchen and I tiled them both. It was a fairly simple matter to cut down the overhang of the sill and then I tiled around and over the edge easily.. It looked far better than if I had left the sill on view.
Oddbod
by Oddbod » Mon Nov 26, 2007 1:25 pm
Hi Cafetorioum. I suspect it means "not for marine use below the waterline". "Yacht varnish" is often just another name for glossy exterior varnish. You can tell if it's a specialist yacht varnish - your wallet will be considerably lighter! You could use it above the waterline if you want. (Although not, as several land lubbers have discovered, on the deck itself. Becomes as slippery as an ice rink once wet, which, lets face, is about 30 seconds after leaving the quay.)
It is currently Fri Nov 22, 2024 5:38 am
