new spotlights
neil
new spotlights
by neil » Fri Mar 30, 2007 1:24 pm
i am trying to install a nem spot light,it only has 3 connections on block.could anyone tell me wher to put either live feed or the swith cable
by sparx » Fri Mar 30, 2007 9:06 pm
how many wires do you have ,this is probably in the projects section already but if not check , you usually will have three lives in a block , two blacks to the neutral blue of fitting remaining wire from switch which is probably black but should be marked as red goes to brown of fitting
If not so reply with how many wires you have
SPARX
It is currently Sat Jan 11, 2025 11:51 am
