Hiding cables for a flat screen TV (chase and fill wall)
eden$
by eden$ » Tue Oct 23, 2007 8:26 pm
Hi all, my first post on here. I've had a good llok around the forum and can't find a post that matches my query.
I'm after suggestions for the quickest way to make good a chased out wall to hide HDMI and power cables. Its a brick wall with plaster skim painted white. Normally I would use bonding/ browning and then finishing plaster, PVA then painted.
I'm wonderingif there is something out there that will do the job in one, so I can just sand and paint (or sand PVA and paint)
blackcat
by blackcat » Wed Oct 24, 2007 8:49 pm
yes there is its a one coat plaster which is as it says is one coat builders merchants should stock it but not all just ask ..but does come in 25 kg bags
________
iolite vaporizer
eden$
by eden$ » Wed Oct 24, 2007 9:25 pm
Thanks for the quick reply blackcat
It is currently Fri Nov 22, 2024 11:11 pm
