Uneven light fitting buld brightness
Harry75
by Harry75 » Wed Oct 24, 2007 12:05 am
Hi, I just swopped two light fittings in my front room that run off one switch from standard ceiling roses to two luminaires. The first light had the three wires L,N and Earth. The second light fitting had two sets of wires. I treated these as a single wire, i.e two L went into one, two Neutral as one and two Earth as one. The lights switch on and off fine. However the fitting with the two sets of wires the bulbs are not as bright as the other fitting? Is this right? I assume not! As you can tell I'm no electrician!
Harry
BLAKEY1963
by BLAKEY1963 » Sun Oct 28, 2007 11:49 am
harry
have u looked at doc s projects on lighting to compare your
connections ??????????????????????
BLAKEY1963
It is currently Fri Dec 27, 2024 2:24 am
