I had a new combi boiler fitted 4 years ago with the HW plumbed in and working fine. I've now plumbed in rads, filled and bled the CH system, but I'm getting no heat in the rads or pipework.
It's a two bedroom flat and I've got a flow and return pipe to one end of the flat with the rads coming off one pipe and joining the other. A 'T' on each pipe makes a flow and return to the other side of the flat.
When the CH is on, the flow and return right by the boiler get warm/hot, but this heat doesn't circulate around the system. I've bled the pump and checked it's rotating - it is and it's hot too.
I've pressure tested it up to 3bar and released the pressure down to 1.5bar and bled the rads again. I haven't yet connected a thermostat to the system (not sure where to), but the boiler's got it's own thermostat.
My boiler is a Worcester 24Si II.
Any ideas?
