2 switches one light *PROBLEM*
darkmagi
by darkmagi » Sat Oct 27, 2007 8:17 pm
I have a double switch in my downstairs hall the right switch controls the light downstairs the left switch controls the light on the upstairs landing, I need to know how to wire the switch up so i can turn the light on the upstairs landing on & off from downstairs & upstairs, The switches have 3 points on each switch a common, L1 & L2 i have a live feed coming into the switch its a red wire I also have a green wire & a black wire from the same cable, I have a red, green & black wire going upstairs, I know the wiring works as i managed to get it working but that was about 4 years ago & i forgot which way round the wires go, The only reason i am having problems with the switch is one of the wire's broke behind the switch & when i pulled the socket from the wall 2 of the wires came loose due to a broken screw holding the wire in place As i was not happy with the switch i bought a new one & now i need to know which way the wires go back, Any help or a link to site with a diagram would be great.
Thanks in advance........... :D
by sparx » Sun Oct 28, 2007 10:18 am
Hi D.
two issues here, first on 'right' sw. ignore L 2, put Live red in C & its blk in L1 [which should be taped red also as is sw.live to light & not Neutral].
second did you have 2 way switching to landing light second switch upstairs working before? or just one double sw. downstairs as 2 one ways? Need to know as 'Left' sw. can be wired in different ways ie if no upstairs sw already then need to add a 3 core cable but if sw. is there then just need to know how upstairs sw. connected ie what colours go where,
await more info, SPARX
It is currently Wed Jan 15, 2025 12:37 am
