converting a large walk in cupboard into an on suite
aston
by aston » Sun Oct 28, 2007 10:50 pm
There is a large walk in cupboard next to the main bedroom which would convert nicely into an on suite. Will I need planning premission and or building regs to knock a hole through from the bedroom for a door way block up the old doorway and fit a small window on the outside wall? It is a bungalow and the outside wall has a high wooden fence blocking it from neighbours view.
LCL
by LCL » Wed Oct 31, 2007 7:56 pm
aston
You'll need building regulations approval. You can do this under a building notice.
You should also contact the planners to see if planning consent will be required, although I'd have thought this unlikely.
Hope this helps.
LCL
It is currently Sun Nov 24, 2024 6:34 pm
